4E-FE — 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
docela by me zajimal, myslite, ze je nekde mozne ho sehnat a idealne i za rozumny peniz vzhledem k cene vozu, aby nestal jak cely auto...
udajne je to motor bez turba... aby mi nekdo nenabizel 4E-FTE
za jakekoliv info budu moc rad...
EDIT: ted jsem o nem nasel toto:
1st Gen 4E-FE
The first generation of 4E engines found in the Starlet GI, Soleil and Corolla models were produced from 1989 until 1996. The engine found in these two models produced 99 bhp (74 kW) @ 6600 rpm and 86 ft·lbf (117 N·m) @ 5200 rpm. this engine had more in common with the 4E-FTE, sharing the same throttle body, and slightly larger fuel injectors.
Specs:
74 mm Bore
77.4 mm Stroke
9.6:1 Compression Ratio
