2x autorádio za Vaší cenu (Praha)
zmaxxx
Příspěvek od zmaxxx »
1) Clarion DXZ648RMP
Mnohobarevný displej(nastavitelné), skrytá mechanika, CD/MP3, nemá USB, dálkové ovládání.
4x53W.
Funkční, hraje dobře, ale trochu diskotéka.
Návod:
http://www.clarion.com/gb/en/MungoBlobs ... RMP-EU.pdf
Clarion DXZ648RMP CD receiver key features
RDS-EON radio with single play CD deck. CD / MP3 / WMA capable
Removable flip-down aluminium front face with case included. Red flashing anti-theft lamp shows when panel removed
Display and control button colour can be adjusted to any one of 80 colours to match car dashboard exactly
CD deck is CD-R and CD-R/W compatible with track scan, repeat and random play
Display of ID-3 tag, WMA-tag and CD text information
Supported bit rates MP3: 8 - 320 kbps and VBR / WMA: 48 - 192 kbps
Z enhancer plus with five settings (Bass boost, Impact, Excite, User customised, No effect)
Magna bass gives boost to very low frequency signals
Subwoofer output with low pass filter (50 / 80 / 120Hz)
High 4 x 51 Watt maximum power output
Stereo RCA auxiliary input sockets for iPod, walkman etc.
Four channel RCA preamp outputs for connecting external amplifier & subwoofer
Separate adjustments for bass / treble / balance / fader
Remote control included
Compatible with Clarion's CeNET range of CD changers, DAB tuner and other multimedia components
High sensitivity RDS/EON/PTY radio tuner with 24 preset stations (18 FM & 6 MW/LW)
Radio preset auto-store function
Attractive blue display, with screensaver and contrast adjustment. Personalised 30 character message can be used as screen saver
CDs in head unit, CD changer or TV stations can be manually named and stored. Display of names scrolls across screen
Retractable rotary controller with non-slip design
Display can be switched between radio information and clock (auto adjusting)
Automatic radio / CD muting when connected car phone rings or is in use
Car phone audio can be played through radio (accessory adaptor required)
Automatic display dimming when vehicle's side lights are turned on
Supplied complete with full installation and operation guide
2) SONY CDX-GT212
Funkční, hraje. Dle mého ucha horší zvuk, jinak OK.
Funkce a vlastnosti
Výstupní výkon 4 x 45 W S-MOSFET
Přehrávání formátů MP3 / WMA
24bitový převodník DAC (digitální / analogový konvertor)
Funkce EQ Lite pro lepší zvuk
Funkce Loudness
Tuner RDS
Snímatelný přední panel
Technická specifikace
Tuner FM
Typ tuneru Tuner SSIR-EXA
ABC (Automatické ovládání šířky pásma)
BTM (Best Tuning Memory)
RDS EON
Přehrávač disků CD
Drive-S
Mechanismus pro 1 x CD
Schopnost přehrávat disky CD-R, CD-RW, CD-MP3
Zobrazení značek ID3 (název skladby interpreta alba)
Přehrávání formátu WMA
Zobrazení textu CD
Rolování názvu (Text CD)
Poměr signálu k šumu (dB) 95,0
Digitální filtr 8fs
D/A převodník 24bitový
Frekvenční rozsah (Hz) 10 - 20 000
Tolerance (dB) +/-1
Poměr signálu k šumu (dB) 120,0
Zesilovač
Výstupní scéna S-MOSFET
Výstupní výkon DIN 45324 při 4 ohmech (W) 4 x 25
Max Výstupní výkon 1 kHz při 4 ohmech (W) 4 x 45
Samostatné nastavování basů a výšek
Funkce Loudness
Jiné
Typ displeje 13 segmentů
Barva displeje 1 barva
Možnost změny jasu displeje ANO
Podsvětlení ovladačů Červená
Odnímatelný přední panel
Integrované hodiny 24 h
Konektor ISO
CENU NAVRHNĚTE, KLIDNĚ ZA ODVOZ - VYZVEDNUTÍ PRAHA 10 (v pracovní době i Praha 4 - Pankrác)
604třisedmsedm846
zmaxxx
Re: 2x autorádio za Vaší cenu (Praha)
Clarion rezervován.
Beru toho Soňáka, na ceně se domluvíme u piva 8)
P.S. Tentokrát nabízím víc než za Pionýra.
zmaxxx
Sony zarezervován. Díky :)
