Torque Pro vysledky pri D-CAT
feronovak
Příspěvek od feronovak »
Zdravim,
pozical som si od brata tu ODB2 sondy na bluetooth a prepojil to s Torque Pro. ECU nehlasi ziadne faults, zato test vozidla hlasi niektore cidla ako fail, ze nepresli. Neviem vsak kodove oznacenia o ktore ide. Viete mi niekto povedat co to moze byt ?
Mode $06 report generated by Torque for Android
===============================================Vehicle Calibration ID: 30551800
Test report:
TID:$05 CID:$01
- Rich to Lean sensor switch time(calculated)
Min: 95
Test result value: 47
FAIL
TID:$05 CID:$02
Min: 600
Test result value: 1,585
PASS
TID:$0e CID:$01
Max: 199
PASS
TID:$12 CID:$01
Max: 112
Test result value: 266
FAIL
TID:$12 CID:$02
Max: 112
Test result value: 3
PASS
Toyota Avensis Combi D-CAT 2006
Ahoj, Mas tam svuj profil vozidla a povolene jen dostupne cidla nebo mas cizi profil a vsechna cidla?
