LED světla- denní svícení
- julinkaa
Vše odpovídá naprosto přesně.jak už jsem psal tyhle světla jakoby navrhla sama TOYOTA i co se tyče kabeláže.
Zde nejaké foto další dodám.
> http://img264.imageshack.us/img264/4570 ... den037.jpg
> http://img690.imageshack.us/img690/245/imgde.jpg
> http://img248.imageshack.us/img248/98/lednolden017.jpg
> http://img412.imageshack.us/img412/1223 ... den019.jpg
> http://img12.imageshack.us/img12/8857/lednolden021.jpg
> http://img690.imageshack.us/img690/3742 ... en022q.jpg
> http://img248.imageshack.us/img248/3263 ... en023d.jpg
> http://img264.imageshack.us/img264/1652 ... den029.jpg
> http://img690.imageshack.us/img690/5701 ... den030.jpg
> http://img12.imageshack.us/img12/2128/lednolden032.jpg
> http://img412.imageshack.us/img412/4000 ... den035.jpg
> http://img690.imageshack.us/img690/4936 ... abele4.jpg
> http://img412.imageshack.us/img412/3314 ... den038.jpg
> http://img697.imageshack.us/img697/5408 ... den039.jpg
> http://img264.imageshack.us/img264/2676 ... den051.jpg
> http://img38.imageshack.us/img38/1831/lednolden052.jpg
> http://img38.imageshack.us/img38/6672/n ... tkdene.jpg
> http://img690.imageshack.us/img690/267/ ... prolep.jpg
> http://img690.imageshack.us/img690/499/ ... imline.jpg
> http://img215.imageshack.us/img215/5649 ... abelev.jpg
> http://img38.imageshack.us/img38/599/pr ... abele1.jpg
> http://img697.imageshack.us/img697/2702 ... abele2.jpg
> http://img690.imageshack.us/img690/6598 ... abele3.jpg
> http://img690.imageshack.us/img690/801/ ... upilou.jpg
> http://img264.imageshack.us/img264/1584 ... aotoen.jpg
> http://img215.imageshack.us/img215/9892 ... ablony.jpg
> http://img38.imageshack.us/img38/1622/p ... dnotek.jpg
> http://img215.imageshack.us/img215/4966 ... raznku.jpg
> http://img264.imageshack.us/img264/8607/ukostenk.jpg
> http://img248.imageshack.us/img248/3189 ... ablony.jpg
ještě k montáži.Pokud je páska nalepena a proveden náčrt rozměru světla (POZOR na lištu jen rozměr skla.)Rozměr celého světla jen do nárazníku a tam může být i o nějaký ten mm.větší. V rozích náčrtu rozměru se provrtají díry o průměru 2mm.Durch lišta + nárazník.To aby když sundáme lištu ,aby jsme věděly kde řezat v nárazníku. DŮLEŽITÉ. šruby které uchycují svělo z vnitřní strany(k SPZ)co nejkratší!!!opíraly by se o ten železný narazník.Ještě k tomu železnému nárazníku:ty kraje co přečnívají se musí až po začátek sváru odřezat.řezal jsem to na místě karbinů ale pozor vše okolo přikrýt!!dělá to tok 4-5 cm.Uřízlé je to vydět i na fotu.Jinak ten plast jsem řezal po vyvrtání třech dir 6mm.vedle sebe ve středu nákresu kterýma protáhnu plátek pily.Řezal jsem přímočarou pilou z malíma otáčkama aby se plast nepálil a je větší přesnost+žiletkovým nožem dořezával kraje ve kterých se z přímočarkou nevejdu..Tot vše NEJDŮLEŽITĚJŠÍ.
Naposledy upravil(a) julinkaa dne pát 11.12.2009, 08:04, celkem upraveno 3 x.
MTZracing
Ake lepidlo sa hodi najlepsie ?cartmanxv píše:Já jsem musel řezat bez prolisům5t píše:Hezké,máte štěstí na prolisy. Já bych musel řezat, ale při troše pečlivé práce ten výsledek stojí za to, zblízka to vypadá jako originál fabrická výroba.
Celá montáž mi trvala cca 3,5 hod + 1 den na vytvrzení lepidla.
Tak jsem si pořídil na T22 tyhle světýlka:
http://www.leddennisviceni.cz/index.php ... 4&cat=1125
tak je nainstaluju a pak sem hodím nějaký foto
Avensis Wagon 2.0 D-4D, 2002
[Quote = "Thomasson"] Tak som si zohnal Na T22 tyhle svetielka:
[Url] http://www.leddennisviceni.cz/index.php ... 4&cat=1125 [/ url]
Tak JE nainstaluj Potom sem hodí nejaké foto:) [/ quote]
Zdravím vospolok.
Teším sa na foto, mam doma takého Ave, AJ farbu Má rovnakú.
: D
Zdravím vospolok.
: D
Stanley T. Avensis 2.0 D-4D, 10/2001, combi
tak toto je zaujimave riesenie pre predfaceliftoveho Avika, vyzera to velmi pekne, avsak na 99% to nebude homologizovane, ale najviac by som pristal na taketo alebo podobne riesenie ( LED v hlavnych svetlach ) co ti poliaci nevymyslia sak?
http://www.youtube.com/watch?v=X9pxngYb1Bs
no a este sa vyjadrim k tym H7 LED ziarovkam, samozrejme, ze to nemoze byt homologovane!!! ved to je ako keby si tam "prasol" HID xenon sadu ( ta by aspon svietila ) ved zeleni ta mozu glbat uz za obycajne ziarovky s modrou bankou, ktore nemaju schvalenie
za svetla na denne svietenie som aj ja, ale takisto sa pripajam k nazoru, ze by mali byt umiestnene v hlavnych svetlometoch, pre mna je to takisto nezvyk ked vidim novu oktavku a ma zapnute iba "hmlovky", v ktorych ma umiestnene svetla na denne svietenie, velmi sa mi paci ake svetla ma od vyroby Opel Insignia alebo aj Audi, maju pekne a intenzitou dobre LED denne svetla
a este som zabudol na dve veci co sa mi nepaci a to aj u originalnych svetlach na denne svietenie a to, ze pri dennom svieteni nesvietia koncove zadne svetla, neviem ako vam ostatnym, ale mne osobne to vadi a nie len mne ale aj ostatnym znamym, druha vec je CENA tychto svetiel, nechcite vediet kolko su vyrobne naklady takychto svetiel 2-3€ ??? aj to som mozno prehnal
, ale tak ked to vezmeme z druhej stranky, niekto sa na tom musi nabalit ( ako pri neustalom meneni typu SPZ ) ...
a proc by proboha mely? z toho isteho dovodu preco zrusili denne svietenie v Rakusku, nesvietili tam vsetci a ked v krizovatke slo 10 aut po sebe a 11 nesvietilo tak si ho sofer nevsimol a nedal mu prednost, pre mna je to iste svietenie vzadu, ked cez den cestujem a vsetky svietia normalnymi svetlami ( svieta im aj koncove svetla ) a nevram mi, ze auto ktore cez den nesvieti vzadu nevnimas menej ako tie co svietia, tak po druhe mam xenony a nie ziarovky a za dalsie svetla, ktorych vyroba stoji nech nezerem 3€ a oni ich budu predavat za 100 - 200 € pripadne tie lacnejsie okolo 50€, tak ver tomu, ze za tie peniaze nekupim jedny vybojky ale 4 alebo aj viac, a to, ze by som zabudol zapnut svetla sa nebojim mam automaticke rozsvecovanie svetiel
protoze mam led denni svetla a zadni tim nesviti tak si vsimam kvuli tomu jak sou videt auta prede mnou a zrovna dneska aj kdyz bylo zatazeno a prselo tak na 100 metru je videt minimum rozsvicenych zadnich svetel, natoz teprve kdyz pere slunko to nevidis ani na 10 metru jestli sviti nebo ne a viditelnost auta at uz vzadu sviti nebo ne je u me stejna na jakoukoliv vzdalenost
spis me serou ti co kdyz trochu prsi tak smazijou mlhovky aj ve meste kde je odstup aut par metru
Ex: Lexus RX 450h rok 13
Ex: Nissan Murano rok 06
Ex: Lexus RX300 rok 99
Ex: Lexus GS 450h rok 08
