Sparovanie kluča
Sparovanie kluča
Ahojte chlapi. Vcera pri obchode som odstavil auto a v pohode zamkol. Prídem späť a otvoriť sa neda. Hladal som aj na Youtebe ako naparovat odomykanie, ale nenaslo mi na bezklučové štartovanie. Neviete mi poradiť ako to sfunkčniť???
Re: Sparovanie kluča
Otec ma podobny problem nejde ani jedno dialkove baterky su ok z nicoho nic prestalo dialkove ovladanie centralu fungovat nema niekto nejaky napad resp. popripade navod ako dialkove sparovat nanovo alebo co by mohlo rusit dialkove
nie. opat ani netusim o ake auto sa jedna a ake su okolnosti problemu
Corolla verso 1,6 2006 znicoho nic prestalo fungovat DO ani jeden nefunguje
A zvnutra ti central funguje?
Skus toto
IF TEN SECONDS OR MORE ELAPSE BETWEEN ANY OF THE FOLLOWING STEPS,YOU WILL NEED TO START ALL OVER AGAIN.PREPARE VEHICLE BY CLOSING AND LOCKING ALL DOORS EXCEPT DRIVER'S DOOR SHOULD BE OPEN AND UNLOCKED.
1)STICK KEY IN AND OUT OF THE IGNITION CYLINDER TWICE WITHOUT TURNING IT.
2)CLOSE AND OPEN DRIVER'S DOOR TWICE ENDING IN OPEN DOOR.
3)STICK KEY IN AND OUT OF THE IGNITION CYLINDER ONCE WITHOUT TURNING IT.
4)CLOSE AND OPEN DRIVER'S DOOR TWICE ENDING IN OPEN DOOR.
5)STICK THE KEY IN THE IGNITION CYLINDER.(DO NOT REMOVE OR TURN KEY)
6)CLOSE DRIVER'S DOOR.
7)TURN THE KEY IN THE IGNITION ON AND OFF TWICE AND REMOVE KEY FROM THE IGNITION.
(AT THIS POINT IF EVERY STEP WAS DONE CORRECTLY,ALL DOORS WILL LOCK AND UNLOCK TWICE TO LET YOU KNOW THE SYSTEM ENTERED THE ADD MODE)
8)PRESS BOTH LOCK AND UNLOCK BUTTONS ON YOUR REMOTE SIMULTANEOUSLY FOR ONE SECOND.
9)WITHIN THREE SECONDS PRESS THE LOCK BUTTON ON YOUR REMOTE FOR ONE SECOND AND RELEASE.
(VEHICLE WILL BEEP TWICE TO LET YOU KNOW IT HAS ACCEPTED THE NEW REMOTE.)
TO EXIT ADD MODE OPEN AND CLOSE DOOR AND TEST REMOTE OPERATION.
You can hold up to 4 remotes for the car.
Skus toto
Pomohlo uz ide dakujem za pomoc
Dovolim si sem dat preklad:
ak prejde viac ako 10 sekund medzi jednotlivymi krokmi, musis zacat odznova. zavri a zamkni vsetky dvere okrem vodicovych
1. vloz a vyber kluc dvakrat po sebe do zapalovania, ale neotacaj nim
2.zavri a otvor vodicove dvere dvakrat po sebe, potom ti ostanu otvorene
3. vloz a vyber kluc zo zapalovania jeden krat, bez otacania
4. zavri a otvor vodicove dvere dvakrat po sebe, potom ti ostanu otvorene
5 vloz kluc do zapalovania, nevyber ho a neotacaj nim
6. zavri vodicove dvere
7. zapni zapalovanie a vypni, dvakrat po sebe a potom vyber kluc zo zapalovania ( ak si doteraz vsetko urobil dobre, vsetky dvere sa dvakrat zamknu a odomknu ako informacia, ze si v tom pridavacom mode)
8. stlac naraz zamknutie aj odomknutie dveri na dialkovom na jednu sekundu
9. do troch sekund stlac na jednu sekundu zamknutie dveri na dialkovom a pusti. (auto dvakrat zapipa a signalizuje ze si pridal kluc)
10. otvor a zavri dvere pre ukoncenie pridavania kluca a mozes otestovat ci funguje
Toto je uz jakaaa spartakiadaMatGO píše:A zvnutra ti central funguje?
Skus toto
Verso Executive '15 / 1.6 D-4D / 17" Anthracite / Touch 2 / White
Suzuki Bandit '12 / GSF-650S / Givi V35 / White
ex-Suzuki Swift '05 / 1.3 GLS / 15" OZ Superturismo WRC / White
Z Japonska
