zapojit v motorovém prostoru dle obrázku, vlézt do auta, zapnout zapalování (NESTARTOVAT!!!) a počítat probliky. Kódy jsou odděleny malou pauzou, pokud je jich víc, po větší pauze se sekvence kódů opakuje.
OBD1 Codes
1	Normal Condition.
2	Air Flow Meter signal.
3	Ignition signal.
4	Engine Coolant Temperature Sensor signal.
5	Oxygen Sensor.
6	RPM signal (Crank Angle Pulse).
7	Throttle Position Sensor signal.
8	Intake Air Temperature Sensor signal.
9	Vehicle Speed Sensor signal.
10	Starter signal.
11	Switch signal.
11	ECU/ECM.
12	Knock Control Sensor signal.
12	RPM signal.
13	Knock Control CPU (ECM).
13	RPM signal.
14	Turbocharger Pressure.
14	Ignition signal.
21	Oxygen Sensor.
22	Engine Coolant Temperature Sensor signal.
23	Intake Air Temperature Sensor signal.
24	Intake Air Temperature Sensor signal.
25	Air-Fuel Ratio Lean.
26	Air-Fuel Ratio Rich.
27	Sub Oxygen Sensor signal.
28	No. 2 Oxygen Sensor signal.
31	Air Flow Meter signal (Vacuum Sensor signal).
32	Air Flow Meter signal.
34	Turbocharger Pressure signal.
35	Turbocharger Pressure Sensor signal.
35	HAC Sensor signal.
41	Throttle Position Sensor signal.
42	Vehicle Speed Sensor signal.
43	Starter signal.
51	Switch signal.
52	Knock Sensor signal.
53	Knock Sensor signal.
54	Inter-cooler ECM signal.
71	EGR System.
72	Fuel Cut Solenoid signal.
78	Fuel Pump Control signal.
81	TCM Communication.
83	TCM Communication.
84	TCM Communication.
85	TCM Communication.
