Nová COROLLA 2019
androids
Re: Nová COROLLA 2019
Příspěvek od androids »
Viete prosm niekto poradit ako (ne)oficialne vyradit komunikacny modul ?
Kód: Vybrat vše
Data sharing
Toyota may also share the data and Signal History, linked to your VIN, described in this Section 12 with its parent,affiliates, third party vendors and business partners for the purposes described in this Section 12. We may also share the data, voice recording and Signal History described in this Section 12 as required by law, legal process, litigation or for customer service purposes.
Data Retention.
For Automatic Collision Notification, Emergency Assistance Button, Roadside Assistance, Stolen VehicleLocator and Destination Assist (see below), we retain the electronic Signal History from your Vehicle for 7 years, unless we are required to retain for a longer period of time prescribed by law, legal process or litigation. Signal History tells us when you or your Vehicle contacted us and your Vehicle’s Location at the point of signal initiation . If you speak with the Response Center from your Vehicle, you may be recorded. We may retain the recording for 7 years or a transcript of the recording for 2 years as required by law and to support requests from customers and law enforcement.
Na inom fore zaujimava poznamka
Kód: Vybrat vše
We are forensic investigators and require the DCM in our new 2019 Corolla to be totally disabled or preferably removed in order to protect our location data from being available or broadcast. It is currently disabled and all spying services off line but the ignition ping to the cellular system is still a concern. Please respond.
Telematics Data Communication Module (DCM) Activation Procedure Supplement: linka
Toyota is connecting a lot of cars to a 'Big Data Center' this year: linka
Verzia mobilu v aute (86740-12040): linka, linka
Ako sa k potvorke dostaneme: linka
DCM module.png (32.71 KiB) Zobrazeno 1697 x
DCM. enjpg.jpg (538.12 KiB) Zobrazeno 1840 x
Naposledy upravil(a) androids dne čtv 28.05.2020, 21:11, celkem upraveno 8 x.
TC TS NG19, 1.8 HEV, 3U5, Executive
m42425
Příspěvek od m42425 »
androids píše:Viete prosm niekto poradit ako (ne)oficialne vyradit komunikacny modul ?
Kód: Vybrat vše
Data sharing
[/quote]
Komunikacni ridici jednotka je prizpusobena tomu, aby ustala autonehodu. V principu ti zbyva jedine precvaknout kabel a vypreparovat zalozni baterii. Obavam se, ze softwarove to nevyresis.
androids
Mne postaci namontovat prepinac/vypinac, ale neviem kde a ako ... oficialny servis ma z takehoto ukonu "strach". Namontujem si vypinac aj sam, ak mi niekto posle info kde/ako :D
m42425
androids píše:Mne postaci namontovat prepinac/vypinac, ale neviem kde a ako ... oficialny servis ma z takehoto ukonu "strach". Namontujem si vypinac aj sam, ak mi niekto posle info kde/ako :D
Jednotka je v palubce. Kde presne, to nevim. Nad hlavou mas tlacitkovy modul. Myslim, ze nejjednodussi cesta, jak zabranit prenosu dat, je odpojeni anteny. Tim by zustala komunikacni jednotka aktivni, a pri startu by se nacetla. Ale svou funkci by neplnila, a byla by z ni cihla.
Dusledky teto aktivity ti ale 100% potvrdi jen Japonci. Na servis je toto tezky orisek.
m42425
Jak pise forenzni vysetrovatel v tvoji citaci. Podarilo se mu hodit jednotku do offline modu. Kdy si pingne do site, ale dale zustava neaktivni. Tak mozna bych se lpo teto stope. Zeptat se jich, jak se jim to podarilo.
m42425
Napada me jedna cesta, a to je zablokovani virtualni SIM, ktera je jednotce pridelena, u operatora.
androids
odpojenim antenky ma napadlo, ale predpokladam, ze sa modul bude pokusat zvysovat vysielaci vykon aby dosiahol fyzicku vrstvu a tym dosiahnem asi aj to, ze budem sediet ako v mikrovlnke ? :o
Lepsie je vypinac na + (-) vodic modulu :?:
MartinHSD
Příspěvek od MartinHSD »
a proč co celé vůbec řešíš ?
androids
pretoze mam slobodnu volbu. chcem mat sebou kontrolovane sukromie. v IT robim dlho a nerobim si iluzie
auto ma telefonny modul, ten je obojsmerny, aj z obrazku je to pochopitelne (ota...), t.j. auto dokaze posielat informacie do centralnej databazy, ale dokaze aj prijimat informacie. existuje bezpecnostna firma, ktora tvrdi, ze neexistuje system, ktory sa neda hacknut a mam pocit, ze som naladeny na taku istu pravdu.
preco asi vydava firma rozne upgrady firmveru ? Je to preto, ze nam pridava nove funkcie, alebo je potrebne distribuovat obcas aj nejake (mozno aj bezpecnostne) opravy ?
Naposledy upravil(a) androids dne čtv 28.05.2020, 08:12, celkem upraveno 1 x.
CommonUser
Příspěvek od CommonUser »
Androids,
uplne ta chapem a suhlasim, ale ako vidis ovecky radsej budu pod dohladom a nechapu dosah tychto rieseni.
ADAC uverejnil clanok, kde opisuje porusenie sukromia (+GDPR) a ako priklad vzal Medure, ktore toho bonzuju totalne nad ramec (+Car Data Monetization).
Potencialny problem vidim v CANe. Teoreticky ti moze potom hlasit Mother ECU, ze mas nieco vadne s EC modulom a chyba moze byt aj na OBD. Otazka je co s tym STK a servis bude robit. Takze radsej prepinac ako prestrihnut kabel aj ked chybu moze ECU uchovavat niekolko startov.
Dufam, ze to zlomis.
PS - V DE je odstranenie eCall dovodom na odobratie technicaku ! (https://bussgeldrechner.com/ecall/#Welc ... CallSystem)
Naposledy upravil(a) CommonUser dne stř 27.05.2020, 20:34, celkem upraveno 1 x.
T27 2ZR-FAE Rice on wheels
Aronnn
Příspěvek od Aronnn »
androids píše:pretoze mam slobodnu volbu. chcem mat sebou kontrolovane sukromie. v IT robim dlho a nerobim si iluzie
Pokud chceš svobodnou volbu, proč sis pořizoval auto, které má tyto systémy. Za mě bys potom nemohl mít mobil, platební katry, televize, počítače ....
Toyota Corolla Sedan Hybrid 1.8 2020
CommonUser
Aronnn píše:
Aronn, toto je cisty alibimzmus od teba.
Nemozes si vybrat nove auto bez toho. Nikto nekontroluje zber dat (a kam vlastne idu ?) ...
Rakusko chce uzakonit v ustave, aby nezmizla hotovost, pretoze sloboda. Salamovou metodou prides pomaly o vsetko, aby si drzal hubu a krok.
PS Vitajte v EUlande:
https://www.autoforum.cz/predstaveni/je ... -nez-v-eu/
https://www.autoforum.cz/predstaveni/pr ... e-mit-dal/
EU cistejsia ako zbytok sveta ...
Aronnn
CommonUser píše:
Aronnn píše:
Nemyslím si, že je to alibizmus, ale tvůj názor ti neberu. To, že si nové auto bez toho nevyberu, s tím musím počítat a proto pokud nechci být "sledován" tak si nový nepořídím. Jen mě osobně zaráží, že všichni jen "remcají", namísto kompromisu a racionálních řešení.
CommonUser
Aronnn píše:Nemyslím si, že je to alibizmus, ale tvůj názor ti neberu. To, že si nové auto bez toho nevyberu, s tím musím počítat a proto pokud nechci být "sledován" tak si nový nepořídím. Jen mě osobně zaráží, že všichni jen "remcají", namísto kompromisu a racionálních řešení.
Takze aj ked mam prachy, tak nemam pravo si kupit nove auto. Fasa pohlad. Taky nackovsky, bud ides s nami alebo proti nam.
Kompromis tu neexistuje. Je to zakon a zaviedla ho nevolena cast EU vladcov.
matus69
Příspěvek od matus69 »
Aronnn píše:.Jen mě osobně zaráží, že všichni jen "remcají", namísto kompromisu a racionálních řešení.
Na to aby zlo zvíťazilo stačí aby väčšina mlčala...
Ps : odstrihnut sa od toho je určite racionálnejsie ako strkat hlavu do piesku a myslieť si, že ťa nikto nevidí.
