ja by som zacal tym, ze chod najazdit 20-50km na 4000ot. To by malo spolahlivo prefuknut egr aj DNPR.redik007 píše:Tak diagnostika ukazala chybu P2002 - Particulate Trap Efficiency Below Threshold (Bank 1)
Mozne priciny:
• DPNR catalytic converter (Manifold converter sub-assembly)
• Differential pressure sensor
• Differential pressure sensor vacuum hose is clogged
• Blockage in vacuum transmitting pipe sub-assembly
• Exhaust gas temperature sensor
• Exhaust gas leaks in TOYOTA D-CAT
• Mass air flow meter
• Engine ECU
takze opat ten D-CAT, a to som konecne prestal dymit (po pridavani zimneho VIFu)
Ak to nepomoze, skusil by som vymenu MAF (vaha vzduchu). No a ked nepomoze ani to, tak neviem, lebo ostatne veci nerozumiem co to je.
Ale viem, ze hlavne tych 4000ot dost vela ludom pomohlo, tak drzim palec.
